Laying New Flooring in Loft Conversion
Posted: Sun May 02, 2010 6:07 pm
by janleemac
Complete novice here and wanted to know your opinions on the best flooring to use in our new loft conversion upstairs. At the moment we have basic chipboard which is not good and flexing badly with loads of creaks. We were looking at t&g chipboard but wanted to best option and lowest cost which dont normally go together! Any ideas anyone?
Posted: Mon May 03, 2010 6:54 pm
janleemac,
You really need to find out why the floor is "flexing badly with loads of creaks". Try screwing down the floor and check on the size and span of joists used.
Posted: Wed May 05, 2010 7:37 pm
by janleemac
Thanks so much for the reply. The main problem is that the floorboards arent good and are not butted together - a few have holes around the edges (these are the really old floorboards from before we converted). We definately need to replace but not quite sure where to start with materials - we hear good and bad things about t&g. Any advice would be really appreciated.
Thanks,
Posted: Thu May 06, 2010 10:12 pm
janleemac,
I would suggest you stick with the old floorboards. Lift them, turn them over and refix moving them closer as you go.
help at hand
Posted: Tue Jun 29, 2010 9:21 pm
by TheDoctor4
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
