Does any1 have any exp of Amtico vinyl?
Posted: Tue Aug 03, 2010 2:29 pm
by davew25
Looking at changing the flooring in our kitchen and weve been looking @ amtico, they've gopt money off at the moment - £58p/m instead of £70p/m
Has anybody had it fitted before? Weve been looking at the black slate you can see it here:
Google "amtico.com/summer/"
Is it easy to lay DIY or worth getting someone in to fit it?
Cheers,
Dave! :roll:
Posted: Tue Jan 18, 2011 6:57 pm
by DaveT
Hi Dave,
I had a go fitting Amtico spacia planks myself and im fairly happy with the result. I ordered the planks and got really, really helpful advice from Design Flooring about how to go about it - Google "designflooringltd.co.uk"
I think it was Toby I spoke to.
The main things were;
Floor preparation!! the floor needs to be smooth. If it is flooboards, then you need to fit 6mm plyboard 1st. If its a concrete floor, as mine was then you need to apply a latex screed ( this I had done by a local fitter )
Apply the adhesive with a trowel blade, let the adhesive go off slightly and then start laying the planks. The planks were fairly easy to cut ( but I fitted the skirting boards after which made it easier )
Overall, yes its not too difficult, but as I ended up with so much adhesive over my hands and it took me a whole sunday to fit my WC, I will get a fitted quote next time!
Good luck!
Posted: Sun Mar 06, 2011 11:15 am
by Graemek
I have laid loads of Amtico - the previous post hits the nail on the head - preparation, preparation!
The sub floor must be sound smooth and dry - either lay a 6mm plywood over timber floors or latex screed over concrete (follow manufacturers instructions especially when comes to DPM).
I think Amtico is the best vinyl flooring out there!
