Intentionally laying a sloping screed.
Posted: Fri Jan 28, 2011 10:56 pm
I want to lay a screed over an existing sloping concrete slab (interior, no DPM in existing slab but plastic sheet test shows no damp whatsoever).
The problem: half the room has a new concrete slab complete with insulation and DPM. I've necessarily had to lay this new slab so it rises 25mm over its 3M length in order to floor over a new 100mm drainage pipe running in it (invert of existing connecting drain is very shallow).
I now want to screed over the adjacent existing slab to matching levels i.e. a finished level which rises 25mm over 3M. The screed thickness will be 45mm thick to zero.
What should I lay down to form this sloping screed from zero to say 10mm? I intended to use a cement:fine sand mix with a good gob of PVA in it bonded to the existing slab with PVA. Should I alternatively buy some SBR bonding additive and use it throughout the new screed, given that there is no DPM?
Any thoughts or better suggestions out there?
The floor is to receive glazed floor tiling so a perfect finish down to zero is not essential.
