repair of end joists
DIY4Me
by DIY4Me » Thu Feb 23, 2012 11:01 pm
I have a hallway that runs between the side of my house and an adjacent room which moves when I walk on it.
I have removed the floorboards and noticed that the joist ends do not sit on anything which is the reason I have the movement in the floor. I've also noticed the joist ends are old and brittle. There is a foundation wall beneath the joist end but this has a peice of 2 x 4 on top which the joists are to reside on. I'd like to have more of a permanent repair than a floating peice of wood which comes away when people walk on it.
what is the best option here:
1 - lay some brick with cement under the end joists
2 - use a joist hanger ?
3 - attach the 2 x 4 to the brick foundation and then fill the gaps with timber to prop up the joists to level the flor ?
can anyone suggest something.
Re: repair of end joists
by welsh brickie » Fri Feb 24, 2012 5:09 pm
extend the joists by bolting a new piece of the same size (1 metre long) to the existing,Then install a new 4x2 sole plate and pack it till its tight under the joists,then bolt it to the wall under the floor.
DIY4Me
by DIY4Me » Fri Feb 24, 2012 6:03 pm
thanks heaps for the advice!
It is currently Sat Jan 11, 2025 4:33 am
