Bouncy floor - sistering joists
Posted: Wed Apr 11, 2012 8:20 pm
by TOMPARKER44
Good evening all,
I have had a good look online and on this forum for what I want to know and have found some useful information but still have some gaps that I hope people can help me with.
History
It is currently a bedroom on the 1st floor in a Vicorian house and measures 3.4m x 2.8m. The joists are 6" x 2" spaced with 400mm centres. When I walk on the floor it bounces and the handles on the wardrobe wobble, when my 2 year old daughter (it's her bedroom) runs and jumps around it sounds like she is going to fall through the floor when downstairs!
I am in the process of splitting this room in half with a stud wall and create a bathroom and bedroom. A heated floor with porcalean tiles for the flooring.
Action
1) I will be carrying out the work this Friday
2) Sister the existing joists with 1 x 6 " x 2"
3) Which ever mechanical fixing method chosen glue will be used
4) 12mm plywood on top of the floor boards
Questions
1) M12 square head bolts, square washers & timber joiners or 6.5 80mm Joist Screws?
2) Will shuttering ply suffice, I can PVA it if need be?
3) Is it worth using joist hangers and if so can I still sister the joists?
4) Slightly off topic - will I need to strip the lath & plaster off the existing external walls when tiling?
Thank you for your time
Tom
Re: Bouncy floor - sistering joists
Posted: Sun Apr 15, 2012 10:17 am
by welsh brickie
you have probably finished now,but if you havent,joist hangers are fine,use dog washers on the bolts to bite into the timbers.
You dont need 12mm osb board use 6mm ply on the floor screwed and glued.
The lath&plaster wall you can dryline with plasterboard and drywall adhesive if its solid.
Posted: Mon Apr 16, 2012 8:46 am
by TOMPARKER44
Hi Welsh Brickie,
thank you for the reply.
I haven't finished it yet as it didn't go to plan! For some reason I decided to get 6" x 1" and rip it down to 5" x 1" and put one either side of the joist but the bolts I had weren't long enough and the wood was a bit wet as it had been outside (treated kick boards).
I have realised that the grade of wood used for kickboards probably won't be as high as that of joists so I will be buying 6" x 2" joists and ripping down to 5" x 2".
I did have 6mm ply but took it back and bought 12mm shuttering ply instead as may screw this directly to the joists and chuck the floor boards - what are your thoughts on this? If I do this then I can put 12mm shuttering ply straight on the floor boards on the landing and it should bring it to the same height as the bathrrom floor (ply + tiles).
Cheers - Tom
Posted: Wed Apr 18, 2012 3:05 pm
by welsh brickie
dont use shuttering ply.If you dont want to use existing floorboards,use T&G chipboard flooring they interlock and glue the joints.Its a much better floor.
