Which Way to Lay Laminate Flooring over an Existing Wooden Floor
Posted: Tue Apr 28, 2015 11:16 am
Hello I hope someone experienced can give me a bit of advice.
I am going to lay laminate floor in a room with wooden floorboards, there is a bay window at one end of the room and the floor boards run lengh tways to and form the bay window. I have read quite a bit on the subject on various sites and there are many conflicting opinions as to in which direction the Laminate should be laid. I think it would be easier to cut the ends of the length if the laminate was running towards/away from the bay window, but that would mean the joints are running in the same direction as the floorboards.
Any advice would be much appreciated.
Thank YOU
Thank YOU
