Plywood Sheets as Underlay on Cooncrete Subfloor for Vinyl Sticky Back Planks
Posted: Sun Feb 14, 2016 11:08 pm
Hi I'm trying to prep my living room floor for vinyl planks (peel and stick kind) and so far I've been advised to use plywood sheets 5.5 mm thick as an underlay to create a smooth surface for the vinyl planks. My question is; what's the best adhesive to use for attaching the plywood boards to the concrete subfloor?
Thanks for your help in advance
