Waterproofing the Join Between Aquastep and Skirting
Posted: Sun Mar 31, 2019 4:48 pm
Hi everyone,
I've had a garden unit installed for use as a home brewery.
Being a brewery there is potential for major spillages (gallons of liquid if something goes very badly wrong!) and frequent drips and splashes.
I have aquastep laminate which I understand will withstand standing water without warping or absorption. I also have a central floor drain which I could direct liquid towards in an emergency.
The main outstanding issue is that the skirting appears just to be wooden, and there is a hairline gap between the skirting and the floor. If a major spillage happened it could easily get behind the skirting and maybe start sinking into the wall.
I know that I can't properly waterproof the entire floor like one of those hospital floors where the floor joins to the top of the skirting, but I wonder if it's possible to get peace of mind by sealing around where the base of the skirting joins the floor.
Would a thick layer of sealant alone do the job, or should I be looking at a combination of this and maybe some sit-on skirting, something like this:
https://www.safetyflooring.uk.com/detai ... gJQCPD_BwE
Or is there something else I should be considering?
Any advice would be greatly appreciated! Many thanks.
