Glueless Engineered Click Fit Laminate Flooring
billobach181
by billobach181 » Fri Nov 02, 2007 2:36 pm
Is it OK to lay Glueless Engineered Laminate on top of Vynil Tiles on a Screeded Concrete Floor or should I remove the Vynil tiles?
On concrete Floors can I use B&Q's Combined Damp Proof and Insulation Membrane on its own or is it best to use a Damp Proof layer as well?
Regards
Bill
NimbusII
by NimbusII » Sat Nov 17, 2007 9:24 pm
Hi Bill,
If the vinyl tiles are not loose and are secure you can lay over them, if it states that it has a DPM and all joins are taped it should be fine as long as you do not pierce it while laying...Just lay one run of the underlay at a time this way you have less chance to damage it but walking on it(if this is the foam underlay I am thinking of from B & Q)
good luck
billobach181
by billobach181 » Sun Nov 18, 2007 10:47 am
Hi NimbusII
Many thanks for your halp.
Bill
It is currently Mon Dec 23, 2024 1:58 am
