drainage pipes in footings trench
Posted: Mon Mar 24, 2008 10:08 pm
by alantoff
whilst digging my foundations i have uncovered a drain pipe running the full length of the footing directly in the centre what are my options will i have to alter the drain ? or will i have to make the extension smaller? also there is a inspection cover which was uncovered under paving slabs which i would have to resite
Posted: Tue Mar 25, 2008 5:35 pm
by ALDA
ALAN,
THE BUILDING CONTROL INSPECTOR WILL WANT TO VEIW THE FOUNDATION TRENCH BEFORE THE CONCRETE CAN BE POURED FOR THE FOUNDATIONS.
SO I THINK HE WILL TELL YOU TO REPOSITION DRAINS AND INSPECTION CHAMBER BEFORE YOU CAN PROCEED AND HE WILL WANT TO VEIW THIS ALTERATION TOO.
(BUT MAY REQUIRE NEW/ALTERED DRAWINGS SUBMISSION TO PLANNING AND BUILDING CONTROL).
EASIEST WAY OUT IS TO REDUCE THE FOOTPRINT OF THE PROPOSED EXTENSION.
(THIS MAY REQUIRE NEW/ALTERED SUBMISSIONS TOO.
THIS MAY NOT BE WHAT YOU WANT TO HEAR.
ALDA.
Posted: Thu Mar 27, 2008 9:07 pm
by alantoff
THANKS FOR THAT ALDA. I HAVE HAD THE BUILDING INSPECTOR OUT AND HE SAYS I CAN EITHER ALTER DRAINS [MAJOR JOB] OR REDUCE THE SIZE OF THE EXTENSION WITHOUT HAVING TO RESUBMIT PLANS. AS I WILL ONLY BE LOSING ABOUT 200mm IN WIDTH I THINK THE SECOND OPTION IS WHAT I WILL BE DOING .CHEERS [/b]
