ventilation a must with flueless gas fire ?
Posted: Mon Apr 28, 2008 9:32 am
by vw754
Is it a must that i have a vent in a room 12x12 if im having a gas fire?
The fire is 2kw high and 1kw low.......plasma gas fire....flueless hang on the wall ?
Posted: Mon Apr 28, 2008 6:03 pm
I would think it does.
Check the manufaturers instructions it'll tell you what ventilation you need.
Posted: Mon Apr 28, 2008 8:04 pm
by vw754
[quote="htg engineer"]I would think it does.
Check the manufaturers instructions it'll tell you what ventilation you need.[/quote]
The Cheshire flueless gas fire can be installed without the need for a flue or chimney. All of the heat from the 100% efficient glass-fronted appliance is directed into the room, with the revolutionary catalytic technology effectively cleaning the combustion gases of harmful constituents. All flueless gas fires require a minimum room size and purpose provided ventilation of 100cm². Refer to product specification. All flueless gas fires should be installed in accordance with BS 5871-4: 2007. All flueless gas fires feature a flame failure safety device and oxygen depletion safety device and must be installed by a CORGI registered installer.
Variable Heat Output 2.0kW High - 1.0kw Low
Wall Mounted
Catalytic Converter
Oxygen Depletion Sensor
Flame Failure Safety Device
£399.99
Posted: Mon Apr 28, 2008 9:41 pm
Well there you go then - that answers your question
"All flueless gas fires require a minimum room size and purpose provided ventilation of 100cm²."
as for the minimum room size read the manufacturers instructions.
Posted: Mon Apr 28, 2008 11:58 pm
by rosebery
"vw754" "All flueless gas fires feature a flame failure safety device and oxygen depletion safety device and must be installed by a CORGI registered installer."
and I'll repeat what I said on your previous thread just in case anyone missed it. I know quite a number of RGIs who WON'T touch these things with a bargepole because they think they are dangerous.
Just for information.
