sealing fire surround
Posted: Sat May 10, 2008 8:21 pm
by Paul Stephens
I have just bought a marble fire surround which when in place sticks out from the chimney breast approx 3inches all the way round as i am having a gas fire fitted i need to make sure the gap is filled and sealed what would be the best way to seal it?
I have been told to use wooden peices and sealant but this does not sound very safe to me could someone advise please
many thanks Paul
Posted: Mon May 12, 2008 10:15 pm
by keitht
cement should be sufficient all the way around the outside of the marble and the inside of the fire opening between the wall and the marble.
Posted: Mon May 12, 2008 11:39 pm
by rosebery
Use an intumescent fire retardant sealant inside the surround. Outside against you can use anything you like really. Just make sure you can decorate it afterwards - ie don't use bathroom silicone or frame sealant.
Do you mean that the fire surround has a 3 inches gap all round from the chimney breast or that the surround is three inches thick?
