Myson (as was ) house warmer back boiler
hamish72
by hamish72 » Tue Jun 03, 2008 1:06 pm
Any one know how the electronics are told that the pilot flame is OK
On this one the pilot light is on correct size and healthy but the spark continues and the main valve fails to open then of course after 60 seconds it all locks out
The manual makes no mention of any thermocouple related to pilot light on and no mention of any feed back to electronics control board
by htg engineer » Tue Jun 03, 2008 4:38 pm
The Pilot electrode (FSD) senses the flame, this sends the signal down the HT lead to the PCB.
Check the flame is touching the electrode, if it is then it could be the pilot assembly, HT lead, or PCB at fault - hard to say without seeing the boiler.
Allure fire front ? or other ?
htg
hamish72
by hamish72 » Tue Jun 03, 2008 7:57 pm
[quote="htg engineer"]The Pilot electrode (FSD) senses the flame, this sends the signal down the HT lead to the PCB.
htg[/quote]
No doubt you are correct as moving the eht lead did indeed solve it thanks for that
I would however love to know the mechanism of how the flame is detected as the eht lead is just connected to earth via the secondary of a high step up transformer I sort of reason maybe the resistance of the spark gap increases suddenly with the temperature rise to stop the spark at that point causing the spark to jump the internal gap on the pcb instead and it is this change that is sensed to open the gas valve
It is currently Sat Dec 28, 2024 11:18 am
