Flueless GAS fires
Posted: Fri Feb 26, 2010 9:37 am
by davejohnparkes
I don't understand the concept of flueless gas fires. Does this mean I can buy a gas fire, fix it on the wall and there is no need to have an outlet for gas fumes?
Posted: Fri Feb 26, 2010 8:14 pm
by DEEARR2
No flue to remove fumes necessary, operates on the catylitic convertor principal. However, must be installaed as per manufacturers instruction taking into consideration calculated unrestricted direct ventilation and fire operating pressure. Recommend Registered installer to carry out install and commission.
Posted: Sat Feb 27, 2010 8:32 am
by davejohnparkes
Thank you for your reply, will take your advice re installation by qualified person.
Posted: Sat Feb 27, 2010 7:26 pm
Go for an electric fire, they're just as effective for heating and look just as good.
htg
