gas shut off to boiler
adrian
by adrian » Wed Oct 03, 2007 1:40 pm
hi i want to shut off the gas to our boiler as we are removing it.
The gas currently enters and then hits a T junction where is sends gas to the cooker aswell as the boiler, what type of fitting can i use to close the pipe going to our boiler??? or am i legally allowed to do this anyway ?
can i use a push fit connector?
thanks Adrian
by htg engineer » Thu Oct 04, 2007 9:27 pm
The fitting to be used has to be compresion or a capillary/soldered. Either a blank or the tee changed for a straight connector
Pushfit is definately not allowed on gas installations.
It is illegal for you to do this yourself.
You need a CORGI registered gas installer to carry out any work to gas pipework or appliances. It's not a DIY job.
adrian
gas boiler
by adrian » Fri Oct 05, 2007 1:48 pm
thanks very much didnt realise that we are not allowed to do it ... we will wait for the gas people who are fitting the new boiler.
thnx again
It is currently Fri Jan 31, 2025 2:28 am
