Loose window frames
Posted: Fri Nov 14, 2008 5:01 pm
by RS
Hi I have some upvc windows but they are loose in the brickwork you can move them about 2mm
Does any one have any ideas how to secure them?
Many thanks
Posted: Mon Nov 17, 2008 9:39 pm
by tim reeve
2mm is not much movment, check the screws each side of the window are done up tight,otherwise drill holes each side using sds 6.5 drill bit and fix with 100mm gold tap con bits,hope this helps.[/code]
Posted: Fri Nov 28, 2008 8:53 pm
by mdpmspitfire
are the frames silicon sealed externally, this prevents movement usually, check the fixings are tight
Posted: Mon Jan 26, 2009 10:39 am
by TheDoctor5
