Removing Door to Change Bottom Seal of Weatherstip
Posted: Fri Apr 01, 2016 12:29 pm
by Old-But-Keen
Hi All, my first post so please be gentle
I found a piece of my bottom weatherstrip hanging from my door and decided it would be a good idea to pull the rubber strip out and replace it
However, I didn't take into consideration that at some time i would need to remove the door to turn it upside down in order to refit the strip
I am concerned about lifting the door off its hinges in case I break something and would ask for your help in reassuring me that this is the correct way to remove the door
I cant find a make on the door so attach to photos that may help
Re: Removing Door to Change Bottom Seal of Weatherstip
Posted: Fri Apr 01, 2016 10:01 pm
by welsh brickie
its the old flag hinges, open the door fully and simply lift it up, its on a pin system and refit the same way
Posted: Fri Apr 01, 2016 11:49 pm
by Old-But-Keen
Thanks for your prompt reply. I will tackle this next weekend
Many thanks
