UPVC door with "Wind Up" mechanism for lock
Posted: Sat Aug 11, 2018 10:41 am
My current front door has what I believe is called a "Wind Up" lock mechanism where you have to rotate the key through 360 degrees several times to engage the multi point lock. Is there any way to upgrade / convert this to a much more modern system to engage the bolts without changing the whole door?
