Industry Standard Window Tolerances
Dreamon100
by Dreamon100 » Tue Aug 11, 2020 9:28 pm
Hi, does anyone know if there is an industry standard tolerance for double glazed units to be not flat / straight?
The issue is if I put a straight edge across my sliding door units there is a clear gap of 3 - 5mm in the centre. As the air gap is supposed to be 20mm it is reduced a lot by the deflection. Surely there must be a ‘Standard’ that should be met.
It is currently Sat Jan 18, 2025 3:52 am
