Nightmare double glazing
Posted: Sat Jan 23, 2021 5:55 pm
We bought a 1920s solid brick build house a couple of years back and have been working through the issues bit by bit.
One problem that is coming up time and time again is regarding the windows. They are uPVC frames, probably fitted 30+ years ago and put quite simply. They leak. Not every one, but a good few of them that we know of, and maybe more we don’t!
As far as I can determine, the water seeps under the frame. Or along a vertical edge and runs down to the corner. I’ve slipped DPC under one of them to see if maybe there are cracks in the frame, thinking I’d see water on top of the DPC sheet, but no. The damp is below the sheet, not above.
The drain holes are clear. The seals SEEM reasonable, but I’m thinking as the drains are clear, would this make any difference if they were letting in a little water as it would surely drain out. The window units are good without any internal misting.
To be honest, it’s a real headache. The house has some damp issues and I reckon 95% of them are due to this same problem at various windows.
How do I fix them? What way SHOULD the windows be fitted that I could possibly check and say these are leaking because they need refitted with ???
If I bought new frames (and with 22 of them, that would be no small bill) wouldn’t they suffer the same problem if fitted in the same way?
I’m thinking about fitting external pvc strips around the frames in an effort to keep the water back perhaps?
Any thoughts welcome...
