Upvc windows not catching in keeps
Posted: Fri Apr 22, 2022 1:09 pm
Hi, I've got a side opening upvc window which has been fine but now when I shut and try to lock it the moving parts will not slide fully into the 'keeps' on the frame (the bits with slots in). The handle will only half close and then stops. The 'keeps' at the bottom are partly engaged but there's a slight gap at the top between the window and frame so it looks like the ones at the top are no longer lined up & won't slide in. Any ideas, can I try adjusting the moving catches at the to move the over a bit?
