Trying to find the manufacturer/installer of my uPVC windows and doors
Posted: Fri Jul 22, 2022 2:26 pm
by SlightlyPeevedSteve
Re: Trying to find the manufacturer/installer of my uPVC windows and doors
Posted: Mon Jul 25, 2022 6:59 am
by nickATS
This depends on what you're trying to find the manufacturer of the windows for - are you trying to match new ones with the old, looking for replacement parts etc?
Let me know, and will try to help. Worth knowing it's unlikely you'll find the exact same windows as building regs have changed on the performance of windows and these products have been redesigned to comply as a result.
Hope this helps
Kind regards,
Nick
Posted: Mon Jul 25, 2022 9:20 am
by nickATS
Sorry forgot to add earlier, these are Roto hinges from the stamp on them and the company is Roto Frank if you wanted to do a search - not sure if I can post links on the forum.
Nick
Posted: Mon Jul 25, 2022 11:15 am
Hi Nick and thank-you for your reply...I'm hoping to find out either the manufacturer so I can find proper instructions to open them up and adjust them as my doors are dropping OR find the installer to see if they are still trading and hopefully get them into adjust them properly. Any help you can give is much appreciated...though I suspect I will have to either get another company in to adjust them or take out that inside screw and see if it opens the hinge cover myself.
Posted: Mon Jul 25, 2022 10:15 pm
nickATS wrote:Sorry forgot to add earlier, these are Roto hinges from the stamp on them and the company is Roto Frank if you wanted to do a search - not sure if I can post links on the forum.
Nick
Hi Nick...sorry I hadn't seen your reply detailing Roto Frank as the manufacturer before I did my last reply...thank-you so much again for you help.
Posted: Tue Jul 26, 2022 5:03 am
by nickATS
To be honest I think your best and easiest solution is to do a local search for a double glazing repair and maintenance company as they're more likely to know how to adjust old doors, having come across most types of door hinges and door systems that may require adjustment.
Hope this helps
Kind regards,
Nick
Posted: Tue Jul 26, 2022 11:08 am
Nick, can I be a little presumptuous and ask if you are an installer or a DIYer and where in the country you are?
Posted: Tue Jul 26, 2022 11:10 am
by nickATS
Hi, no, not an installer, just have 30+ years in the trade and now work with the glazing industry and have the aluminium trade supply website if you do a search for that - we help homeowners and the trade. :)
Not quite sure if you can post links on these forums.
