TILT AND TURN WINDOW
Posted: Sat Oct 13, 2007 4:38 pm
by lindsay prout
IN THE BATHROOM ,THE TILT AND TURN WINDOW WHEN SHUT HAS A DRAFT
FROM THE BOTTOM RIGHT AND IT IS QUITE NOISEY, ANY IDEAS ON HOW
TO SORT THIS PROBLEM OUT. THANK YOU
Posted: Mon Oct 15, 2007 5:32 pm
by mutti uk
Hmm, I had the saame on a few of our windows... B&Q had some rolls [draft exclusion type] which i stuck around the window to seal it on top of the seal that was there but had obviously failed, not sure what the roll/tape was called, but if you ask one of the guys in there, they will know what you need, they had different kinds too. Foam/Plastic, depends what you think and easy to stick on... Hope that helps, i'm looking for answers on my own probs and came across yours!
