Where to buy the tiny Polystyrene ball (blown) insulation
Posted: Wed Jan 28, 2009 9:04 pm
by ShaneCook
I'd like to fill a cavity with that blown in insulation, the small Polystyrene ball type. I have access to the top of the cavity so I can just tip in the insulation until it fills up the space. The space is sealed, so the balls will not blow out. However, I can't seem to find anywhere that sells the insulation. Anyone suggest somewhere?
Kind Regards,
Shane Cook.
Posted: Fri Jan 30, 2009 10:55 am
by TheDoctor5
