Insulating/ dry lining cold walls in bedroom
balletpixie
by balletpixie » Fri Jan 15, 2010 1:39 pm
We need to know the best option for dealing with cold walls in a north facing bedroom which accumulates condensation and consequently mould also. Our house is 1930's solid wall construction so no cavity.
We have started to use a dehumidifyer which is helping with the moisture.
How can we insulate the walls? Can we dry line without losing too much space?
Suggestions very welcome :roll:
by stoneyboy » Tue Jan 19, 2010 10:41 pm
balletpixie,
Unless you include a ventilated gap behind any dry lining your condensation problems will get worse. 25mm gap 50mm foam backed plasterboard - you're going to loose 75mm.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Fri Jul 02, 2010 9:07 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Sun Dec 22, 2024 11:41 pm
