Solid Brick and Dorma Roof - Where to Start in Terms of Insulation?
Posted: Thu Jan 29, 2015 8:25 pm
Hi we are spending our first chilly winter in our dorma bungalow. The rooms upstairs are warm enough but the ground floor is difficult to heat. Can take 3 hours for 15-19deg and won't go much higher especially at ground floor level.
The exterior walls are mainly solid brick, the extension is cavity with no insulation. The floors are concrete. The roof is a mixture of sloping and flat roof dormas with 100mm rafters and only 50mm glass wool. No loft space. The very large windows are thin double glazed hardwood. There is central heating with Valiant combi and have already adjusted rads for ground floor heat. The ground floor ceiling is high but the upstairs ceiling is low.
I appreciate many potential improvements like interior, exterior, cavity wall insulation, foam board rafter/roof insulation and new windows and doors. But can't afford it all so what might be the most cost effective improvement to start with?
Thanks.
Thanks.
