Sorry to hijack, but StoneyBoy what you described regarding the cold floor and ceiling in the dormer described my issue perfectly. I've been searching for how to fix it, but every posts seems to be about insulating the dormer itself.
If I could be as bold as to show you my issue, in the image works.
I tried to create a diagram showing what I mean as it's a bit confusing.
The part of the loft outlined in orange is insulated on it's lower side with 300mm glass wool.
The part of the loft outlined in blue is inaccessible and not insulated.
The blue line along the window shows the air gap for the dormer.
The blue arrows show the ventilation path which leads directly from my bedroom into the upper loft and out the vent.
It should be noted that the ceiling just inside the front door is stone cold to the touch, that bit of loft is COLD.
The cold air literally "pours" through the window sill of the dormer and across the bedroom floor. It actually "sounds" like a window is open.
This is since I got the loft insulated and the vented slates installed. It was no were near this bad last winter. Middle of the night without heating on, the dormer can get as cold as 13*C, only 7 above outdoor ambient.
Are there any solutions to stop that air flow while maintaining enough ventilation for the lower roof AND the dormer?
