No room for insulation
Posted: Sun Aug 28, 2022 6:11 pm
I have a concrete foundation slab base.
Looking at putting down insulation but everywhere it says this should be 70mm thick then on top of to put tongue and groove chipboard.
However I don’t have 70mm of height between the door into the flat and the slab base. It is more like 35mm.
Is there a thinner alternative to 70mm of insulation or another way of getting the right amount of insulation down and still leaving room for a solid underfloor and then flooring to be put down without having the front door obstructed.
Or would raising the threshold into the property without restricting the head height too much be the way to go
Or would that have its own restrictions under building regs.
