Insulation in 1970's Very Cold House
Posted: Thu Jan 19, 2023 5:42 pm
Hi, came across this old thread and the post with the photo from paulca is my situation as well (original topic here: insulation-in-1970-s-chalet-style-house-t49352.html). My house is so cold it makes me want to cry. Don't know paulca if you did anything but any ideas please.
My house is detached but essentially the same
- Dormers built into roof (no insulation in front or sides)
- Flat dormer roof (no insulation)
- Sloping roof leading to sloping bedroom ceilings (no insulation)
- Small loft space used as storage (boarded with some, but inadequate, insulation under boards. But even if it was better its essentially useless as the heat just gets out elsewhere)
What on earth should I do. Can I remove the dormer cladding and insulate underneath and replace. Do I need to remove the roof tiles, insulate under between the rafters and replace.
Or could I try retrofitting insulation from inside i.e. remove ceilings and wall plasterboards, insulate under and then reattach (or just use insulated plasterboard) and replaster. As the loft space would still be cold internal sounds best right?
Any help appreciated.
