fitting a cast iron victorian spiral stairvcase
GSBST
by GSBST » Sat Dec 24, 2022 4:55 pm
I would like to fit a dismanteld cast iron spiral staircase but my floor to floor is 230cm and this staircase is 268cm. Is it possible to remove the top two steps to retrofit it?
Re: fitting a cast iron victorian spiral stairvcase
by stoneyboy » Sun Dec 25, 2022 9:37 pm
Hi gstsb,
Provided you do not end up with a very different riser height you should be ok.
It is currently Thu Jan 02, 2025 2:51 pm
