external render ratio/materials
Posted: Mon Apr 13, 2009 11:10 am
by bodgitnscarper
i am looking to render a small external wall. can anyone provide the correct ratio mix and sand type, will normal builders sand do? will i need any additives?
Posted: Mon Apr 13, 2009 11:47 pm
by rosebery
1 cement to 6 sand is normal but it does depend on the wall material. Use Sharp sand. Builders sand won't work and if you use that it will all fall off in due course. PVA the wall first and slap the render before it completely dries out.
