Can Efflorescence occur on mortor joints also?
Posted: Tue May 29, 2007 12:03 am
by bbillcee
i had new patio built around certain bricks the mortor is very white compared to rest of brick
also the bricks where it is were old brick used from the old porch....could it be some reaction to mortar?
Posted: Thu May 31, 2007 8:15 am
by thedoctor
Possibly or it could be a different mix of sand and cement used in these areas. Efflorescence can certainly be found in brickwork joints but this forms a powder on the surface of the joint as well as (usually) being white in colour.
Posted: Thu May 31, 2007 8:21 pm
by bbillcee
this is what i mean!! please tell me i can do something about this!
[URL=http://imajr.com/000_0109_87730][IMG]http://imajr.com/th/000_0109_87730.jpg[/IMG][/URL]
white staiing on brickwork
Posted: Sun Oct 07, 2007 2:54 pm
by glen-paul wilson
it is a common missconception that this problem can be removed by brick acid but the truth is that all brick acid will do is attack the sand in the mortar what you need to attack is the lime to do this you need to use phospheric acid and not hydrochloric acid which is commoonly known as brick acid & alloy wheel cleaner trust me i was in the concreet industry for thirteen years and now own a cleaning copany that specializes in brick cleaning among other things google trucking clean manchester
