Render that has had filler and sanded flat
Mini M
by Mini M » Thu May 26, 2022 12:51 pm
Hi All,
Need some advice on render. The house has render on the exterior walls sponged and then a scribed block pattern (not sure the correct name for that).
It had a fair amount of hairline cracks which we got someone to fill; however, they sanded it flat and now it doesn't match the texture of the surrounding render.
Is there anything I can do before repainting as it looks a mess, it's an end of terrace so a fair amount of area to cover.
Thanks,
M
Re: Render that has had filler and sanded flat
by stoneyboy » Fri May 27, 2022 9:44 pm
Hi mini m,
Suggest you use a coarse textured masonry paint, sandtex fine will not hide the surface discrepancies.
It is currently Wed Nov 13, 2024 12:05 am
