1930's bathroom bare walls
Posted: Sat Mar 29, 2008 6:33 pm
by yvonnepaul
Hi we have just taken off 3 layers of bathroom tiles and all the plaster fell off so took everything out including ceiling we now have bare brick which is great condition.
Need to plaster what can experts recommend to us
a plaster board dot and dab
b plaster board on timber frame
I take it we use the plaster board that has one side insulated for extra protection and also you cant build a frame around the window area so what do you do in these places
any comments will be greatly appreciated
Posted: Sat Apr 26, 2008 10:20 pm
by Briggy
Hello, personally i would dot and dab a moister resistant plasterboard (green board) and skim, foil back will have to be battened out first, so with my suggestion this will eliminate packing out battens for plumbing up, so less time consuming. Try using a supplier like ccf or cpd, they specialise in materials for the plasterer and dryliner etc........ Also not sure what you mean about your window, could you please elaborate? Hope this helps. Regards!
Posted: Wed May 14, 2008 8:27 am
by yvonnepaul
[quote="Briggy"]Hello, personally i would dot and dab a moister resistant plasterboard (green board) and skim, foil back will have to be battened out first, so with my suggestion this will eliminate packing out battens for plumbing up, so less time consuming. Try using a supplier like ccf or cpd, they specialise in materials for the plasterer and dryliner etc........ Also not sure what you mean about your window, could you please elaborate? Hope this helps. Regards![/quote]
thanks for the advice, the main wall where the shower will be is quite easy to use water board as its got wooden internal posts to fix it to. As for the window its brick so I guess they would dot and dab that area as well????
plasterer should be arriving soon!!!!
Posted: Mon Jun 16, 2008 3:28 pm
by Fishie42
Hi, we are very soon to be in the same situation as above! We have removed all the tiles from a fully tiled bathroom and the plaster has come with them!
We have also lost the entire ceiling due to large cracks. My question is..!
Is it best to do the whole room and ceiling in aqua board, or just the area around the bath, that will have the shower over it? and the rest in normal plasterboard? The area around the bath is the only area we shall be tiling, the rest of the room will be skimmed and painted.
Any advice appreciated!
Posted: Wed Jun 18, 2008 7:57 pm
by kbrownie
spanner in the works here.
Right As a tile backer for bathrooms aquaboard great. But if your going to board and plaster standard board no problems. If ceiling still up even though cracked overboard saves time and mess.
Regards
KB
Posted: Fri Jun 20, 2008 10:02 am
by Fishie42
Thanks for the help.
Its too late for ceiling im afraid! The rest of the house is a mess (bathroom is second room in the house to be done - rest is still in the 1960's!!!), so we weren't to concerned about that.
