Plastering two backgrounds at once
Posted: Sun May 25, 2008 10:55 pm
by scroogemonster
I need to plaster a stud wall beneath my bedroom bay window. There is a timber frame which is boarded with plasterboard. The side of the plasterboarded frame is attached to the brick wall of the house. How do I plaster over both surfaces. Do I undercoat the brick and skim both with multifinish, or do I use one coat for the whole plastering job?
Posted: Mon May 26, 2008 12:17 am
by rosebery
You should use bonding on the brickwork first then skim both.
Alternatively "dot and dab" new plasterboard over the brickwork and the existing plasterboard (to get an even finish) and then skim the lot.
