Skimming
Posted: Mon Jul 28, 2008 11:00 pm
by paulpa66
As a diyer, i really want to learn to plaster.
I have read the guides.
If skimming a large area, how do you stop the plaster put on first from going off before you finish the wall/section. And how do you get a consistant 1mm/2mm thickness across the area?
Looking at booking onto a plastering course but would like practice first
Posted: Tue Jul 29, 2008 9:14 am
by TheDoctor4
Have you had a look at the DIY Projects section of this site: https://www.diydoctor.org.uk/projects.htm There are several projects on plasetering that may be of some use to you: https://www.diydoctor.org.uk/projects/Plastering.htm
Skimming
Posted: Sun Aug 03, 2008 4:22 pm
by LonPLast
Stop plaster going off too quickly by using PVA solution applied to area to be plastered.
Keeping thickness consistent is practice & using consistent strokes.
If you are going to do a course do it BEFORE you wreck your own house!!
Also if you want to practice buy some plasterboard, stick it in the garden\garage & go for it. Plasterboard is the easiest surface to plaster onto (no PVA required) & will help you get a feel for it.
Unfortunately plastering is mainy about practice, best of luck...
Posted: Wed Aug 27, 2008 12:07 am
by chris_on_tour2002
stopping plaster going off - pva first and SPEED! consistent thickness? practice! unfortunately there are no real shortcuts to to developing a knack. the more you do it the better and faster you become.
