Which plasterboard
Posted: Wed Nov 05, 2008 2:31 pm
by TomA
Can anyone recommend an insulated taper edge plasterboard for use in a basement conversion? Also would it be necessary to use any additional insulation besides the board?
Posted: Sun Nov 09, 2008 5:17 pm
by kbrownie
Have look on british gypsum website will probally help with your choice of board.
KB
Re: Which plasterboard
Posted: Sun Nov 16, 2008 11:09 am
by ricky68
[quote="TomA"]Can anyone recommend an insulated taper edge plasterboard for use in a basement conversion? Also would it be
necessary to use any additional insulation besides the boarheers[/quote] call BG tec department tell them what you have,they will tell you what you need and email you all the info you need
Posted: Fri Nov 21, 2008 1:29 pm
by Enda
Hello there - I have a few questions;
1. I had a friend help me with a studded partition wall in my garage & that worked out great. He built the studded wall using 1.5 * 2.5 in lengths of timber and I finished it off using Kingspan sheets between the studs and standard plasterboard on top. What I wasn't sure was if the gap between the Kingspan and the second plasterboard sheets should have been filled with additional wool insulation or if that gap/vacuum is required?.
2. I had a lot of materials left over as I'd considered insulating the full internal outside wall of my garage so I can use as workshop/office area. I have Kingspan and the 1.5 * 2.5 lengths left over and was advised I could lay the timbers on their sides so I have a 1.5 in deep frame (instead of the 2.5in and lose too much area) on the wall. As the Kingspan is 2in then it would be deeper than the frame so I was told I could cut the sheets with a saw down the middle and use as two thiner sheets?. I just want to know if this is OK to do and if I should put the silver coated side against the plaster wall or leave it facing outwards (I'm assuming it should go in against the plaster wall as it's flat and smooth unlike my saw cutting?)?. Again I'll be left with a gap between the insulation and the plasterboard and again I'm wondering if this is OK?.
Ready to go once I know!. Enda.
Posted: Tue Jan 27, 2009 2:10 pm
by TheDoctor5
