Wall boards on batons
Posted: Mon Jan 19, 2009 11:56 am
My house is 1930's with cavity walls and I'm renewing my first-floor bathroom. I’ve removed the old tiles (and most of the old plaster) from one exterior wall which is to be fully tiled and will include an area of a new shower. My options seem to be:
a) Have it re-plastered, (I can’t do that myself) but I’m told it will take ages to dry before it can be tiled.
b) Dot and dab, but I’ve never done this and this is quite a large wall for a first attempt.
c) Fix batons to wall and mount 12.5mm plaster board and Aquapanel where required.
I’ve pretty much decided that option c is the only one open to me, so I’m left with a few questions:
1. Should I start with a sheet of polythene?
2. Should I put insulation between the batons? (I’ve seen some interesting looking panels in Wickes that are 25mm thick fibre with foil each side).
3. Can I tile straight on top of the panels (plasterboard and Aquapanel) when done?
Grateful for some guidance.
