Join between masonry and plaster wall?
Posted: Sun May 02, 2010 1:30 pm
A friend has asked me to insulate his timberframe porch stuck onto a masonry building. I'm planning to put in the insulation and then dryline as the owner does not want wet plastering.
At present the joins between the timber and masonry wall are cover with some wood trim. What would be the best way to do away with the trim and make a nice continual join? I was thinking of using scrim tape over the join as with the other dryline joints, but this may leave a raised surface on the masonry wall?Would it really be best to wet plaster?
Much appreciate any advice.
Toby
Toby
