attaching vapourblock pb to battens
Posted: Mon Jun 14, 2010 7:26 pm
by tomtom08
Pretty straightforward question - I'm drylining a wall using vapourblock plasterboard and want to know (i) if it'd be ok to use pb screws/nails with this as they'd obviously pierce the metallic film and so possibly compromise the vapourblock effect, and (ii) if these aren't ok, will standard plasterboard adhesive adhere to the metallic backing and hold the board in place securely. Thanks for any advice.
Posted: Tue Jun 15, 2010 11:55 pm
by Dan the man
Plasterboard adhesive will not stick to Foilbacked boards, you need to screw/nail them.
Posted: Wed Jun 16, 2010 9:44 am
by tomtom08
As I suspected - cheers for that - saves me having my pb falling off the wall!
Posted: Sun Aug 01, 2010 10:25 am
by grimsmith
I know this is a month later than when you posted your question, and you have probably finished the job several times over too! But just to set your mind at rest, the PB you are using is 'Vapour-Barrier', so when you screw them to battens, they should be fixed tight enough to prevent any vapour escaping anyway, it doesn't matter that the metallic film is pierced. I there were large rips elsewhere open to the air, it might. Incidentally, screwing PB to battens/joists is better than nailing, firmer fix and no vibration causing other nail heads to break through.
