wall repair
Posted: Sun Nov 28, 2010 4:18 pm
by neald
hello everybody,i need to repair a wall that has had dado rail on,the are a few holes/patches that are from the liquid nails and pins that held the rail onto the wall,what i would like to know the best plaster to use to cover the holes i.e.multi-finish? thanks neal
Posted: Thu Dec 02, 2010 8:44 pm
by JRS
If they are not too big you could just do a couple of fills with easy fill, or you could get some one time which is great for small holes.
Posted: Fri Dec 03, 2010 8:11 pm
by neald
[quote="JRS"]If they are not too big you could just do a couple of fills with easy fill, or you could get some one time which is great for small holes.[/quote] the holes aren't that deep and some area's are only the thickness of the emulsion on the plaster,would it not be possible to easi fill the holes in one fill? neald
Posted: Sat Dec 04, 2010 6:50 pm
by JRS
Should be fine just to fill then, May take a couple of fills to be flush.
Posted: Sun Dec 05, 2010 7:48 pm
by neald
ok mate,i'll let you know how i get on
