Using MDF instead of plasterboard
Posted: Fri Jul 20, 2007 11:50 pm
by Steven
I'm going to be lining the walls and putting up new partition walls in a shop unit. As there's going to be customers coming and going I was considering using MDF instead of plasterboard for the walls to make it a bit tougher, is this the right thing to do?
Also, I've read the article on painting MDF but was wondering what I need to do to prepare MDF walls for wallpaper and tiling?
MDF or Plasterboard...?
Posted: Sat Jul 21, 2007 4:36 pm
by martin497
Personally I wouldn't use MDF as this to me seems like a very expensive way to build a wall. I would also give alot of thought to the weight issue,
MDF weighs a ton.
If you are determined to use MDf then you can just prime the boards with a pva solution prior tom tiling, but dont paper them as you will always see the joins in the boards through the wallpaper.
I would stick to plasterboard walls.
