two coats of finish
Posted: Sun Jul 22, 2007 2:41 pm
by rnd
hi , just a question i am a little confused about . when skiming on to bord's, should two coats be needed does the second coat need to be mixed to the same consistancy as the first coat , or is it two different texture's
regards
Debbie
two coats or one...?
Posted: Wed Aug 01, 2007 5:22 pm
by martin497
The correct way to skim is to use two coats of finish.
You can make the second coat to the same consistency if you want or you can make it a touch wetter if that feels better for you.
you dont need to make quite as much for the second coat either..!
Posted: Thu Aug 02, 2007 10:54 am
by rnd
excelent thank you martin
Posted: Tue Aug 07, 2007 7:49 pm
by rambo77
different people have different methods id mix the second coat just slighty wetter but maybe thats just me
Posted: Tue Aug 28, 2007 12:14 am
by damo
2 coats allways but the second should be a tad wetter and only half as much needed as it goes further
Posted: Fri Aug 31, 2007 8:20 am
by rnd
cheer's guy's thank's
