is there a difference
rnd
by rnd » Fri Jul 27, 2007 1:17 pm
can anybody tell me whats the difference is between board finish , and thistle multi finish ,and which would you recomend to put over boards .
i have skimmed over board before but have never used board finish . is this better than the multi finish , and should i now start to use the board finish , or does it make no difference .
kbrownie
Re: is there a difference
by kbrownie » Wed Aug 15, 2007 7:47 pm
[quote="rnd"]can anybody tell me whats the difference is between board finish , and thistle multi finish ,and which would you recomend to put over boards .
i have skimmed over board before but have never used board finish . is this better than the multi finish , and should i now start to use the board finish , or does it make no difference .[/quote]
Hi, you can use both types, which every suits you and your pocket. I'd personally use board finish.
Hope that was of any help.
KB
rnd
by rnd » Thu Aug 16, 2007 4:59 pm
it helps very much thank you so much
It is currently Sat Nov 23, 2024 8:47 pm
