what to do with new plaster
Posted: Sun Oct 07, 2012 6:10 pm
by whitehart
Hi All
i have recently had two rooms plastered, can i paint straight onto the plaster or do i need to put a base coat on first??
thanks in advance
Re: what to do with new plaster
Posted: Sun Oct 07, 2012 9:06 pm
by welsh brickie
paint a pva solution on the walls first.
Posted: Sat Nov 17, 2012 8:23 pm
You only seal with PVA if you're going to use oil based paint as the finish. If you're going to use water based emulsion - just use a cheap white emulsion first.
