Cracking/blistering bathroom wall/lime plaster
Posted: Fri Aug 14, 2020 12:07 pm
by Jo1501
The paintwork in my Mother’s bathroom is cracking/blistering after 3-6months of application. It is a Dulux bathroom paint. The problem walks are exterior. The lime plaster below has previously been patched with a modern filler & sealed. Is the problem due to condensation or the lime plaster reacting with the modern filler/non breathable paint? Is solution to remove existing plaster & replaster from scratch?
Re: Cracking/blistering bathroom wall/lime plaster
Posted: Sat Aug 15, 2020 9:27 pm
Hi jo1501
If you have lime plastered walls it is likely that they are solid, it is not a good idea to used a non-permeable paint on these wall because damp cannot escape.
Suggest you scrape off an area of blistering and see where the fault is.
