plastering breeze blocks
Posted: Thu Oct 04, 2007 9:55 pm
by jezlings2
Can you plaster straight onto breeze blocks or do you have to plaster board first?
Posted: Fri Oct 05, 2007 7:56 pm
by LCL
jezlings2
Are your blocks new? If so they are likely to be concrete or insulating blocks (technical point).
Answer to your question:
1. You can dot and dab. This is plasterboard bonded to the wall on gypsum dabs and skim finish. (make the walls sound hollow and is used a lot in new housing). Quicker to apply and less water, therefore less shinkage afterwards.
2. A two coat plaster finish. Something like Thistle Undercoat, bonding or renovation plaster as your base coat (correctly applied - not to a bone dry wall) and finish with a thistle multi finish.
Hope this helps
LCL
Posted: Sun Oct 07, 2007 8:47 am
by jezlings2
Many thanks mate was great help.
