coving cutting 45 o (degree) internal angles
Posted: Wed Dec 19, 2007 1:30 pm
by boab
how do you cut 45 o angles on coving? iv seemed to get hang of 90 o internal and external cuts, but this has got me stuck. please help
Posted: Sat Dec 29, 2007 12:04 pm
by Holywood
Sorry don't have an answer but I suggest you log this query under carpentry/joinery as a joiner will best give you the answer you need rather than a plasterer. This is the sort of problem many joiners will have come across only in wood so the same principles will apply.
Good luck.
Posted: Sun Jan 06, 2008 11:49 am
by kbrownie
Hi boab, There is a project under "angles" in the DIY PROJECTS on this site, it will give you a better idea and description with diagrams than I can!
Best of Luck
KB
Posted: Sun Jan 06, 2008 12:22 pm
never cut 45o angles for coving but have for skirting -
like 2 - 45o cuts = 90o
2 - 22.5o cuts = 45o
can't see why it wouldn't work with coving too.
Posted: Sun Jan 06, 2008 3:45 pm
by thedoctor
See also the project on coving. Cutting coving angles is slightly different because the coving has to be the same way up for all cuts.
