heating
Posted: Wed Apr 02, 2008 6:45 pm
by hud
hi,some of my rads are heating at the top and down the sides but not in the middle ,what wll the problem be and how can i fix it myself?thanks .
Posted: Thu Apr 03, 2008 10:53 am
by nitro23456
most likely sludge build up inside the rads. difficult to say 100% with the info provided though.
How old is your system and has it been flushed recently?..... if not for years it is likely sludge build up and the remedy would be draining and power flushing the system.
if it is one or two rads you could isolate them, take them off and hose pipe them through in the garden until water is clear. However sludge is like a spider - where there is one there is more.
hope that helps.
Posted: Thu Apr 03, 2008 1:04 pm
by chris_on_tour2002
probably a build up of sludge, eliminate this first. remove offending rads, flush out with a high pressure hosepipe and replace. see if this makes a difference. if so, add a sludge remover/inhibitor. if its severe it may need a power flush by a professional.
