running bath waste
chris_on_tour2002
running bath waste
by chris_on_tour2002 » Thu Apr 03, 2008 1:15 pm
hi,
about to install a new bathroom suite and a new toilet (toilet in an adjacent room). as i am changing the toilet i want to change the soil stack which is cast iron and quite corroded.
the new bathroom is a complete revamp and i want to run the waste for the new bath and shower under the floor to minimise boxwork (which i think always looks nice for about 5 minutes but starts to look tatty very quickly).
the problem is the run of the joists - the best way would be for me to run the waste out through the wall, the externally along and into the soil stack. but a friend tells me that you cannot run the bath/shower/basin waste into the soil pipe - has to be different drains?
could somebody please clarify? surely it all ends up in the same drain eventually anyway? we do not have a cesspit or soakaway.
thanks,
chris
by htg engineer » Thu Apr 03, 2008 3:57 pm
You can run bath, shower and wash basin wastes into the soil stack. You can't run soil waste into a rainwater gully etc - think they must have gettin mixed up.
It's worth looking into the best way to do this though - you don't want the waste pipes opposite/level with the toilet waste - as if it backs up it could come up into the bath, shower etc. Tee in above where the toilet waste is then any back-up will be visible at the toilet bowl first.
chris_on_tour2002
by chris_on_tour2002 » Thu Apr 03, 2008 4:29 pm
thanks htg engineer, thought this was the case. i was going to run the waste from the bathroom to a point just below the toilet waste. i can see why this is not such a good idea!
It is currently Wed Jan 08, 2025 5:26 pm
